Machine Vision
How to convert image from usb camera to array
Hello Everyone
I am trying to use a USB camera and then convert the image obtained to array format so that i can have access to each pixel intensity. But when i am using IMAQ image to array, it gives error like invalid image formatThought i an see the image in image window it is just that i can not convert it to array. A little help from anyone is appreciated
Regards
Chauhan
(3,859 Views)
You are using a USB camera, which generates color images.  You are using ImageToArray for grayscale images, which is why the image format is not compatible.  You need to do one of two things:
1.  Convert your color image to a grayscale image.  IMAQ Cast is the easiest way to do this - just create a second image that is grayscale and use it as the destination.
2.  Use ImageToArray for color images to extract the data you need.
Bruce
Bruce Ammons
Ammons Engineering
(3,846 Views)
Thnaks
IMAQ cast did the work.
(3,834 Views)
