Machine Vision
How to create a valid template image for multi geometric patterns matching?
Dear All,
I'm trying to implement multiple Geometric Patterns matching. And I modified the example "Match Multiple Geometric Patterns" but keep getting error 1074395628.
What I did are:
1. Adding video flow to the example to make it match features in the video.
2. There are three preset image templates in the example, I tried to replace it with an image template created by myself but keep getting the error. I attached the image template I use.
How I created the image template:
I used several methods to create it but none of them work in the example:
1. I used the Template Editor to create a .png file;
2. I used another example called "Pattern Matching" to extract a template.
It seems that the error always appears after the "IMAQ Learn Multiple Geometric Patterns.vi". Does anyone have some idea about what I should do? I got stuck in this for a long time. Thanks!!! I also attach the modified example below.
(3,497 Views)
Accepted by topic author ZY-TreeHouse
Hi ZY-TreeHouse,
This error sometimes comes up when an invalid template file is used. It could be either a file format issue or the image size being too large. The forum post linked below goes through a few more troubleshooting steps you can try:
Error -1074395628 IMAQ Learn Multiple Geometric Patterns
https://forums.ni.com/t5/Machine-Vision/Error-1074395628-IMAQ-Learn-Multiple-Geometric-Patterns/td-p...
Melanie P.
Technical Support Engineer
(3,460 Views)
Thank you very much Melanie!
(3,446 Views)
