Machine Vision
How to detect glass particles in glass bottle
I am using count object 2 function to detect non transparent (Black) particles and that is working fine. Now I want to detect Transparent (Glass) particles from the same Image.
Glass bottle is filled by water and mix particles are present in the glass bottle.
I also tried to use filter in then used the count object 2 function but it is not working properly.
Please suggest the solution
Any help would be highly appreciated.
Jasraj Rajpurohit
(2,644 Views)
Can you share images?
Amit Shachaf
(2,623 Views)
  • FPA
Jasraj Rajpurohit
(2,596 Views)
