Machine Vision
How to determine image type in IMAQdx
You can use the IMAQ property node to determine the image type when creating images.  However, when I try this with IMAQdx I get 0 for bits per pixel and I do not see an image type like for IMAQ.  I am creating 8 bit images when my camera is color.  How do I determine the image type from the camera file?
(5,762 Views)
Accepted by topic author DarkLordOfG
Hi rammer,
IMAQdx exposes an attribute called "TypeOfImageInUse" which will give you the expected image type for the current camera settings. However, any of the IMAQdx functions that return an image will automatically convert the image to the appropriate format automatically, so you normally don't need to worry about it.
I don't believe that attribute is currently directly exposed as its own property node, but you can use the CameraAttributes -> ActiveAttribute/ValueU32 ones to query it like any other dynamic camera attribute.
Eric
(5,750 Views)
can you post a screen shot.  Not sure what VI you are talking about.  It must come from the FG not a camera attribute.  Thanks.
(5,731 Views)
Eric,
Never mind my last post.  Figured it out.  THANKS!
John
(5,729 Views)
I can't find "TypeOfImageInUse".  Can you please post a screenshot?
(4,370 Views)
Hello! This is an old post, I recommend that you create a new post for your question to get faster and better responses from the community
(4,361 Views)
