Machine Vision
How to display result of vision tools
I have builded a new script by NI Vision Assistant.I have transfered it to VI.In this script,I used straight line tool and builded two lines.With the tool of caliper,I defined the intersection of these two lines.This intersection was displayed in script of  Vision Assistant,but in vi ,it disappeared.How can I display it in my vi?Can anyone help?
(2,442 Views)
Hi Papigo,
 Once you finished the caliper, you would get the position of lines. So you can write code to draw lines by overlay function.
Ricky
(2,434 Views)
Thank you for your advice.It helps a lot.I added some overlays,and it worked very well.In this application,I have  only  two overlay to edit,but if in some application,I have 10 or even more to display.It would take much more work.So why do the system display the result in Assistant while undisplay it in vi? In VisonPro of Congnex,it dispays all results automatically by system.
(2,374 Views)
You can share this idea under Vision Idea Exchange: https://forums.ni.com/t5/Vision-Idea-Exchange/idb-p/visionideas
(2,352 Views)
