Machine Vision
How to extract a part of image from another lager image?
Hi .Please download the images named "333-1.png" and "333.png" from the attachments first.I want to  extract the  image named "333-1.png" from the image named "333.png" automatically .But how can I do ? I hope that you can help me.Thanks.
melo_xu
(4,279 Views)
Please stick to a single thread. Since this post contains the attachment we will continue here. Try applying threshold and extracting using particle filter.
Dont go to this thread again
(4,276 Views)
Accepted by topic author melo_xu
This will work
(4,271 Views)
Thank you for your help ,Muks! I have solved this problem by your VI. I hope that I can learn more from you ! If I have any other questions ,I think I will still need your help.
melo_xu
Message Edited by melo_xu on 05-26-2010 09:00 AM
(4,263 Views)
melo_xu
(4,260 Views)
Glad to help. Dont forget to mark the post that helped as the solution..:smileywink:
(4,256 Views)
HI Muks,
Are u doing extract.vi with vision assistant? I want to extract the car license plate number from the cars with vision assistant. I already modified and tried ur program. It's not work with my car photos. Can u show me the script that u use in this program?
(3,724 Views)
