If I understand you correctly, you are trying to generate and view a 3-D image in LabVIEW. Is that correct?
You can view 2-D images using a 3-D display by using the IMAQ 3DVIEW VI located in the Image Manipulation palette within the Vision Utilities subpalette. However, there is no fixed algorithm for generating and displaying three-dimensional images using Vision tools.
You could try something along the lines of building a 3D array where each layer of the array represents a single image. You could then manipulate and display the array on a slice-by-slice basis, each time only displaying a 2-D image. There is not currently any way to display a 3D image that is not a simple 3D surface.
If you have any additional questions, please let me know.
Scott R.
National Instruments.
Scott Romine
Course Development Engineer
