Machine Vision
How to get a trigger signal from d-sub on NI PCIe-1427 frame grabber
Hello
I am using a PCIe-1427 frame grabber with a CCD camera. The camera works with a light source and I need to make a strobe light using a 15-pin D-SUB connector on PCIe-1427 frame grabber. I know that there are 4 trigger signals available to send on D-SUB connector. Does anybody know how can I do this? Is there any example or maybe somebody has any ideas? Thank you
(2,783 Views)
Hi Ivan,
I'm sure you have seen this document, but I would like to first link the user manual for the NI 1427
NI PCIe-1427 User Manual
On page 3-3, you can find the pinout of the DSUB connection. The TTL trigger lines are the first four pins. For the software aspect, I recommend trying out the HL Pulse Generation example which can be found in the NI Example Finder by following the steps below:
  1. Open any LabVIEW Window and click Help -> Find Examples...
  2. You will see a file tree organized by task. Navigate the tree to Hardware Input and Output -> Vision Acquisition -> NI-IMAQ -> Signal Input and Output
  3. There are several examples in this folder which may be helpful. The HL Pulse Generation example provides an easy UI for configuring a trigger on any available line so you can familiarize yourself with the API
Please let us know if this is a sufficient starting point for you and thank you for posting!
Austin
Staff Software Engineer
NI
(2,739 Views)
