Machine Vision
How to implement a bolt and screw inspection system?
I want to implement a Bolt and Screw inspection system using a camera. For example finding screws withouts enough grooves or without a head.
I'm familiar with image processing algorithms but I don't have a global overview about the approach.
From where should I start?
This is my plan:
1. Find screws by Object Detection
2. Find head and count the grooves on the bolt.
(2,711 Views)
I think Vision Assistant is really helpful for you : D
It has "Solution Wizard" and you can find some example of vision application!
I believe you can develop the application with NI Vision system.
Certified LabVIEW Developer
GCentral
(2,687 Views)
