Machine Vision
How to increase the fps of a online tracking program?
Hello 🙂
I am trying to track the motion of little beads at 12 Hz of sampling frequency. For that purpose I have written a LabVIEW program to online track the position vs time of that beads. However I only achieve 2 Hz of sampling frequency.
The program works as follows:
(1) Take an image through 1394 drivers. I use the SNAP 1394 function.
(2) Find the centroid of every particle in the image. (This lasts less than 50 ms)
(3) Repeat the same process with a timed loop.
I don't use any graphical representation that could slow the process.
Any ideas to increase the sampling frequency? May be changing the SNAP function? Consider a triggered adquisition?
Thank you in advance,
Raimon
(3,055 Views)
I think the Grab Acquire and Sequence functions may be more appropriate (and faster) for what you're trying to do.
(3,049 Views)
Thank you!
Using the GRAB function I can achieve 6.5 Hz of sampling frequency. In order to make sure that always I have the same delay between frames I am thinking in triggering the camera. But I don't know how to do it. Can I use the GRAB function in trigger adquisitions? Is it possible to generate a trigger with the same LabView program? is it necessary to remove the timed loop of my program?
Any suggestions would be appreciated!!!
Thank you in advanced,
Raimon
(3,022 Views)
