Machine Vision
How to interface serial camera for labview ?
Hello.
I have a instrument that outputs a serial UART. I would like to interface this with LabView.
And how to use IMaQ Serial read VI ?
Thank you
(3,562 Views)
This IMAQ serial read VI is intended to be used with the serial interface that comes with the Camera Link interface. To use it you need to first open an IMAQ session for your camera.
Your camera manufacturer should provide the serial command syntax to change the settings of your camera.
Most of the time, the camera should send back a short message for each command received. So you will have to use both red and write serial fonction to have a good com.
Regards
(3,549 Views)
