Machine Vision
How to make PCIe-1429 snap image with standard mode instead of free run mode
I use PCIe-1429 card and want snap the image, but the camera can only worked under ‘free run" mode(trigger mode), how to make the camera worked under "standard" or "overlapped" mode?
(3,925 Views)
What are you trying to accomplish?  Do you want to trigger every frame from an external trigger?  Do you want to start a freerun grab with a trigger?  What camera are you working with?
(3,851 Views)
