Machine Vision
How to output a binary bitmap from a dll?
Hi!
I have made a type of a picture generator - a dll written in C++/MFC.
Now I need to make it compatible with LabView 6. The problem is that I
don't know what my exported function should return, nor what the
parameters should be. I have seen similar functions in IMAQ, which
somehow return an image in a void *image. Well, basically all I need
to know is what the function should look like and what it should
return.
int GetPicture(void *image , ..., ..., ??)
Fill void *image with what?
How should I allocate memory for the image pointer?
I want to be able to transfer a picture from this function and output
it in a LabView program.
Please, help me! 😃
/Chris, Sweden
(3,358 Views)
LabVIEW provides a VI for just this purpose. It's called IMAQ ArrayToImage.vi and it is designed to take in a 2D array of pixels (U8 or I16) and convert it into the *image datatype.
This way you can write your function to return a 2D array of U8s and just pass it into LabVIEW.
KyleV
(3,358 Views)
How will LabView know the size of the 2d array? That's the whole
problem.
What should the C-function look like? Where should the memory be
declared? In my dll or LabView?
Kyle V wrote in message news:<506500000005000000AB2B0100-1042324653000@exchange.ni.com>...
> KyleV
(3,358 Views)
