Machine Vision
How to preset the Enable pin functions by software using the frame graber 1422?
Hi
I'm looking for any information related to how to configure by software the enable pins on Frame grabber PCI-1422. I found some examples on NI WWW showing that Frame synchronisation signal was wired to Enable A and Line signal synchronisation signal was wired to EnableB.And this was for an Area SCAN type sensor. But in any case that i wish to use my actual setup/cable for a Line SCAN type camera, do I have to modify my cable in order to connect now the Line synchronisation signal on Enable A? Or there is a possibility to define this my software (Camera file for example)
Thank you
regards
Bruno
(4,150 Views)
Hi bjsimard,
I think your best bet in this case is going to be modifying your cable. I don't think you'll be able to modify your camera file in order to do this.
(4,108 Views)
