Machine Vision
How to read the picture in tif format
I use Labview2017. I want to read the picture in tif format, and get its gray value of every pixel.What should I do?
(2,571 Views)
Accepted by topic author RuomingXin
Hi Ruoming Xin
You need to use IMAQ to read image and if it's colorful, also need to change it to gray by extraction.Then you could get an array's gray value by a VI in pixel manipulation group called "image to array".
See the below picture.
Ricky
(2,549 Views)
Thanks for your answer. I have been solved my problem.
(2,520 Views)
Thanks for your answer again. I got a new problem just now.
The picture is an 8-bit grayscale image. I used 'IMAQ ReadFile 2' and ‘IMAQ Imagetoarray’ to get its gray value. I found that it became a color map.The original image is shown on the right. And the picture made in gray value is shown on the left.
Can you help me
(2,515 Views)
Not know your application why need change it back to 2D picture control. But I think this link will solve your problem.
https://forums.ni.com/t5/LabVIEW/Color-table-question-gray-scale/td-p/335312?profile.language=zh-TW
thanks,
Ricky
(2,502 Views)
Thanks for Your answer. I have been solved my problem.
(2,482 Views)
