Machine Vision
How to register multiple positions dating circle?
Hello.
I'm doing a project in which I look at a point through eye and pick up the coordinates. I'm doing a part that I look like a point and collect several coordendas for 20 seconds and give the arithmetic mean. Expect an answer that is a great help.
regards
(5,163 Views)
-What's your point(red marking?) in the image?
-Are you able to locate the point and it's co-ordinates?
-Do you have an array of co-ordinates if so use http://zone.ni.com/reference/en-XX/help/371361J-01/gmath/mean/
uday
(5,161 Views)
Thank you very much for responding. My question is how can I register several coordinates "Circle detection" that point for 20 seconds
(5,158 Views)
-Well i'm sorry i don't think i understand what you are asking for. Can you explain it little more...
uday
(5,154 Views)
Hello.
Sorry for not explaining well. I am making an eye tracker device. I have a camera that follows the eye, the program I made whenever it detects the pupil paints me a circle. What I do is look a circle for example that of the previous image with the red mark, and save coordendas circle that show on the outside. When I refer to save coordendas is because having no fixed eye as there is a certain as there coordendas different when looking at the circle. Resumiento I detect several coordenas to get multiple circle detection and x and y, the question I have as I save those coordinates.
(5,138 Views)
Hello.
Explaining better, as I can save s (x, y) of a circle every time "Found circle " detection a circle
regards
(5,133 Views)
