Machine Vision
How to save an image produced from an array?
I want to take an image that I created using IMAQ 'array to image' and save it.  The goal is to be able to using this image to create a template in Vision Assistant and match other images produced by similar arrays to this template.  Any ideas?
Thanks!
(4,178 Views)
Accepted by topic author Godnumber1
Godnumber1 -
The easiest thing would be to save the image as a .png file.  To do this, call IMAQ Write File and select the PNG version.
Greg Stoll
Vision R&D
National  Instruments
Greg Stoll
LabVIEW R&D
(4,167 Views)
Thank you Greg!
(4,143 Views)
