Machine Vision
How to select ROI automatically
Additional a nice tutorial for adaptive Thresholding:
Adaptive Thresholding in IMAQ Vision
http://zone.ni.com/devzone/cda/tut/p/id/2986
Please have also a look at the example at the end of the document.
Regards
Pixar
Message 11 of 15
(1,990 Views)
Hey Pixar,
I have tried your method. Because of the changeable brightness of Live Video, I can't get ideal conclusion.  Do you have another idea?
regards
Guo Zhongge
Message Edited by Guo Zhongge on 06-01-2010 02:51 AM
Message 12 of 15
(1,973 Views)
Hey Pixar,
regards
Guo Zhongge
Message 13 of 15
(1,972 Views)
Hi
The only way is that you do a histogram measuring, after that you know the values of the bright regions.
Then you can set the value for the Thresholding.
Regards
Pixar
Message 14 of 15
(1,956 Views)
I have tried many methods to my dynamic illumination and dynamic position live video analysis. I think it is impossible to analyze automatically. Therefore I try to select the ROI manually. But there are still two diffcult points.First one is I have to select two ROI on Image, second one is I have to make sure the two ROIs are in a same size. Do you have any idea?  Thanks in advance.
Regards
Guo Zhongge
Message 15 of 15
(1,918 Views)
