Machine Vision
How to select the target when migration to LabVIEW
I'm migrating from VBAI 3.0.1 to LabVIEW 8.5. The script will read an image file instead of grabbing from a camera. The migrated LabVIEW VI will get part of a larger LV application which will run on a WinXP OS.
The inspection in VBAI is working fine and is loading the image from the right location.
After migration to LabVIEW the image is not found. I can see that the path is correct in the "Inspect Setup-Cleanup.vi" as parameter for the "Simulate Acquisition" step. Debugging into the code I found that the file will be read by a VI named "IVB Simul IMAQ Setup (for RT).vi". This VI checks the path for location on a C: drive. In my case the image is located on the 😧 drive and the VI is changing the path to an not existing folder.
How can I tell during migration that my target is not a RT system but a Windows system?
I expected to find a VI named "IVB Simul IMAQ Setup (for Win).vi" in the VBAI\LV\subVIs folder but it seems it does not exist.
Changing the check from C: to 😧 and running the migrated inspection it works fine.
Message Edited by waldemar.hersacher on 03-05-2008 04:34 PM
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,569 Views)
Hello!
The problem is coming from the VI IVB Simul IMAQ Setup.vi which doesn't recognize the images coming from other places as C:
In VBAI 3.5 the problem is resolved.
As workaround you should change a constant in the IVB Simul IMAQ Setup so that it can manage images from other places as C.
As attachement the changement which has to be done.
Best regards
Ken
(3,555 Views)
Dear Ken,
I have found the same location by myself and changed the "C" to "D" in the other case.
My problem is that I have to do this each time I migrate the inspection. Even when I document this with the project in the case one of my colleagues has to work on the project he may forget it.
Changing to 3.5 would only be a solution if the update is for free. The license will be shifted to our customer and I don't think he will buy the update.
Waldemar
(3,538 Views)
