Machine Vision
How to set MAX Configuration
Hello folk,
How can I set Output image to Intensity plane or Value plane in MAX as in IMAQ Extract Single Color Plane.vi?
Any help very appreciate..
Thanks and regards
(3,842 Views)
If you are using the PCI-1411, you can select the output as color, or a single color plane. It is one of the options under the properties.
I don't think you can do it with any of the digital camera cards or Firewire.
Bruce
Bruce Ammons
Ammons Engineering
(3,842 Views)
Dear Bruce,
Yes, I'm using PCI-1411. I tried to configure this in the same way you suggested me, but I've seen the drop down of only RGB, R, G, B, HSL, H, S, L. So, I don't know how to set the output to be Intensity plane or Value plane.
Thanks and regards,
(3,842 Views)
In the HSL planes, the L plane is Lightness. This is practically the same thing as Intensity or Value. I think it is a slightly different definition mathematically, but probably not enough to affect you. So, try out the L plane and see if it works.
If the difference between Lightness and the others is a significant one, you are going to need to acquire color images and extract the plane you need using the color tools in the Vision toolkit.
Bruce
Bruce Ammons
Ammons Engineering
(3,842 Views)
Bruce,
Thank you so much for your helpfulness. I'm trying on the L plane and considering whether it works.
(3,842 Views)
