05-29-2007 03:28 PM
06-01-2007 01:28 PM
Hello HuShane,
Are you actually getting an error (with an error code?) or does your global variable simply not get set? I am assuming your are using the Set Global Variable step, and setting the variable to a measurement. Doing this should always set your boolean variable to the pass/fail status of your measurement. Could you post some screenshots of this error, along with version information of VBAI?
Jasper S
06-01-2007 02:35 PM
I don't get an error message. The global variable just defaults to the set to acquire Image - Step Status. A measurement that is allows true. I cheated it. I created a second global variable and it worked. Since I needed two, I had to make 4 global variables. Two that always default to the acquire Image - Step Status and two that remain at the measurement I need. I found this works, I just will always have two global variables that I will never use. My version is 3.0 Build 20060912141620.
