Machine Vision
How to set the dpi of a JPG with IMAQ?
With the IMAQ routine GetFileInfo you can read the calibration of the pixels in pixels per unit of length (the number of dpi, default 72).
Does anyone know how to set the value and the unit?
Certified LabVIEW Developer (CLD)
(3,131 Views)
Manu,
It sounds from your post that you are interested in doing Simple Calibration. This envoles setting the distance that each pixels represents in real world coordinates. For instance, you can set an x and y reolution for each pixel and actually take measurements as a function of some length such as inches instead of in pixels. There are several shipping examples for calibration that may help you. A vi you may look into is IMAQ Set Simple Calibration.
C:\Program Files\National Instruments\LabVIEW 6.1\examples\Vision\2. Functions\Calibration
Best Regards,
Chris D
(3,131 Views)
