10-08-2010 07:48 AM
Hey!
I don't find a property class in property node, to change the Exposure time on Balser acA1300-30gc. Can you help me?
Thanks!
Solved! Go to Solution.
10-08-2010 01:18 PM
You would set the ActiveAttribute property to the attribute you wish to control and then you can use all the properties associated with it. See the snippet below:
Eric
10-11-2010 05:39 AM
It works! Thanks!
