Machine Vision
How to solve school bus routing problem (SBRP) using gurobi optimizer in matlab interface?
An example to solve MILP using gurobi optimizer in matlab interface is given as follows:
function[] = mip1()
names = {'x'; 'y'; 'z'};
try
    clear model;
    model.A = sparse([1 2 3; 1 1 0]);
    model.obj = [1 1 2];
    model.rhs = [4; 1];
    model.sense = '<>';
    model.vtype = 'B';
    model.modelsense = 'min';
    clear params;
    params.outputflag = 0;
    params.resultfile = 'mip1.lp';
    result = gurobi(model, params);
    disp(result)
    for v=1:length(names)
        fprintf('%s %d\n', names{v}, result.x(v));
    end
    fprintf('Obj: %e\n', result.objval);
catch gurobiError
    fprintf('Error reported\n');
end
end
After running this code we have output like this:
          status: 'OPTIMAL'
     versioninfo: [1x1 struct]
          objval: 1
         runtime: 0
               x: [3x1 double]
           slack: [2x1 double]
        objbound: 1
       itercount: 0
    baritercount: 0
       nodecount: 0
x 0
y 1
z 0
Obj: 1.000000e+000
Now I want to generalize this code to solve school bus routing problem.
I have modeled SBRP problem like this:
minimize sum_{i!=j} c_{ij} x_{ij}
subject to sum_{j=1}^{n} x_{ij} = 1, for i=1,2,...,n
               sum_{i=1}^{n} x_{ij} = 1, for j=1,2,...,n
               sum_{i,j \in s} <=|s|-v(s);
               s c V\{1};
               |s|>=2;
               x_{ij} \in {0,1}; i,j =1,2,...,n; i!=j
c_{ij} is cost
v(s) is an lower bound on the number of vehicles required to visit all vertices of s in the optimal solution.
S is a subset of V\{1}, where V is the set of bus stops.
Please help me.
Thanking you,
Ajay
Message 1 of 1
(4,177 Views)
