Machine Vision
How to update 1394 camera files programatically?
I would like to programatically update the camera file for a 1394 camera. The Attributes for the camera can be changed as demonstrated in the shipping example. I would like to save these to the camera file so that these become default. Are the current Attribute settings kept in memory so that a single "Save" call updates all the changed Attributes in the camera file or do I have to manually open the camera file and update the specific Attributes?
(4,961 Views)
Avasil
You are correct in your understanding. The attributes are updated in memory and will persist when you call the save function. The save function takes 2 parameters. The first is the current session and the second is an optional filename. Specify a filename if you want to save to a specific location. Leave the filename blank to save to the default location.
In LabVIEW, call
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\vision\driver\IMAQdx.llb\IMAQdx Write Attributes.vi
In C/C++, declare the function
IMAQdxError NI_FUNC IMAQdxWriteAttributes(IMAQdxSession id, char* filename);
The import library will contain correct linkage.
Once the attributes are saved, they will loaded by default when you next open the session.
Hope this helps,
Johann
(4,955 Views)
What driver package is the Imaqdx Write Attributes.vi part of?  I don't seem to have that particular VI in my Imaqdx drivers.  I need to programmatically save brightness gain etc.
nacree
(4,715 Views)
Nacree,
The "IMAQdx Write Attributes" VI comes with the NI-IMAQdx driver.  This is part of the "Vision Acquisition Software" package and comes with any hardware you purchase.
If you don't have the VI, then I would double check in Measurement & Automation Explorer (MAX), under Software, to see if you have NI-IMAQdx installed.
Rishi L
(4,697 Views)
