Machine Vision
How to use NI OCR function to read character more correct
Hi,I'm using NI OCR to read character,but I feel this function is not good ,I don't konw hot to use it more better.
Someboby please help me.
(3,466 Views)
What is the IMAQ version you use for training?
Did you have more than one sample for the same character in training?
Is your camera mounted prependicular to the text you want to read or with projection that require calibration?
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,464 Views)
Please try posting the image here. We could suggest some preprocessing that will help OCR.
(3,460 Views)
