Machine Vision
How to use "imgplot" to display image on a Control in VC++?
I want to show a image on a static picture control on dialog by vc++, the function I used was a NI-IMAQ "imgPlot" to draw image on the control, beacuse it is easier and faster with capture card.
imgPlot ((GUIHNDL)hFrameWnd, pImg, 0, 0, src->width, src->height,0, 0, IMGPLOT_MONO_8);
I get the control's HWND by GetSafeHWnd() to set the first paprameter and set the second parameter with a buffer pointer, since I just want to test, so buffer data is not obtained by capture card, but from a file. No image display on the control, no errors display either, why
Message 1 of 1
(3,437 Views)
