Machine Vision
How to using NIVBAIInspectionEngine for Labview call VBAI by Active X
solution for NIVBAIInspectionEngine
by Example  C:\Program Files\National Instruments\Vision Builder AI 3.5\ActiveX Support\Examples\LabVIEW    using  NIVBAITargetControl  But I want using NIVBAIInspectionEngine to SetTimeout Method because I Call VBAI using LabVIEW more 1 Minite ---->  VBAI time Out
(3,508 Views)
Hello robotview,
Have you tried specifying a value for the case structure timeout value? I would recommend creating a constant of > 1 minute ( >60000 ms). Give that a shot… I hope this helps you out 🙂
David G
Sales Engineer - SE Michigan & N Ohio
(3,486 Views)
