Machine Vision
How trigger an external device from GIGe camera I/O
Hi all
My setup is like this:
PTgrey gige camera
LV 2014 sp 1 64 bit
What i am trying to achieve is this:
taking constantly pictures in a while loop ( ~ 1 fps) and do some processing in the loop with  the exposure time  set manually  based on the fluorescence of the material under investigation. Exposure time varies from 10 - 999 ms. I need to triger an external device from the camera I/O during the exposure time only. For this i am writting directly to the camera's registers. For long exposure times > 300 ms everything works fine but with shorter exposure  time (<150 ms) the image taking and the outpur signal is out of synch. I ve tried using the low level snap and grap but none of them works.
Isnt it fine to do single shot acquisition on every cycle or do i have to setup a buffer?
Who can please enlighten me on this.
Cheers
Billy_JJ
(3,644 Views)
Without knowing the exact model you are using (and exploring the manual) and having a better understanding of what you want to do, it is hard to give a perfect suggestion. However, generally most cameras will let you configure the GPIO output lines in a way that they will be synchronized with the exposure of the camera.
(3,629 Views)
