Machine Vision
How use video generator ni5431 with visual c++
i use a ni5431 video generator with visual c++.
i generate a ccir signal and i want to modify attributes IMAGE_TOP, IMAGE_HEIGHT and IMAGE_WIDTH. When i change one of these attribute with VDG_SetAttribute(****,int) i can't obtain a signal.
Thank you for your help.
(3,018 Views)
Proably the reason this question has gone so long without an answer is that the Vision forum only covers our NI Image Acquisition hardware (along with all NI Vision software), and not our signal generator hardware. That hardware is covered in the Signal Sources forum under the Measurment Hardware section, which is serviced by a different set of Enthusiasts and experts. If you ask your questions there, you should get a quick response.
(3,018 Views)
