Machine Vision
I Cannot Make a False Camera Go Away in MAX
Yesterday, I mistakenly assigned the Basler driver to a Basler USB camera in NIMAX.  I figured out how to undo that and assign the NI driver I wanted, but now there is an erroneous "camera" that shows up on my list of camera choices, even if I have nothing plugged into the USB ports.  See attached image.  When a user attempts to open this nonexistent camera, imaqdx error 0x80004005 pops up.
I thought I would be clever and delete everything from C:\Users\Public\Documents\National Instruments\NI-IMAQdx\Data, thus eliminating the problematic iid file, but when I do that, the system automatically creates a new iid file, using the lowest available camera number.  What is generating that file?  How do I make it stop?
Thanks in advance for any help you can offer.
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(4,928 Views)
You will need to uninstall the Basler software first.  THis is a virtual driver, so it remains even if the actual camera is removed.  You may also need to go into the IMAQdx\data directory and remove the camera files there.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(4,925 Views)
Thanks!  I was hoping I could do it without removing and reinstalling the Basler software, but I guess not.
Forbes Black
(4,922 Views)
