Machine Vision
I can only aquire now.How to process an image ?
Hello sir,
    I am N.Iniyan Thiruselvam, Final Year BE SW Mechanical, PSG college of Technology. I have Licenced version of LabVIEW 8.2. I have inslalled device drivers and also NI IMAQ 4.0. Now I can only aquire an image in LaBVIEW software using Basler IEEE 1394 camera. I have now finished interfacing the camera. I need to process the aquired image and compare it with a standard template and check whether the the captured image matches with the template or not. What should I do? Should I install some other device drivers. I need to do it in LabVIEW itself without using Vision Assistant or Vision Builder. Is it possible?
(3,506 Views)
IMAQ just allows you to aquire images.  I don't think Labview has any vision processing functions included.  You need to purchase NI Vision software to process the images.  This is quite expensive but I think you can download it and try for 30 days.
Good luck,
Dan
(3,479 Views)
Does your package have the ImageToArray function.  If so, you can convert the image to an array and use array math to compare to a template...(which will also need to be in array format.)
(3,454 Views)
OH thank you very much. Your information is very useful for me.
(3,438 Views)
