Machine Vision
I can't initialize my GigE camera problem ID:0xBFF6902C
when i try to initialize the camera of Baumer TXG04h, it seems to have a red cross in the MAX,and I get the error message: Error 0xBFF6902C Unable to connect to the camera.
Then i used a procilica GE680 instead, but the error occurs still.
and i also check the Ip configuration, I think it is correct.
also, it is strange that everything runs well with the demonstrate program provide by Baumer.
I try to figure out what's going wrong, but after searching NI.COM, I got no answer.there is nothing i can use in Troubleshooting GigE Vision Cameras
Really appriciate for your help!!!!
(6,808 Views)
(6,807 Views)
It's may be the problem of antivirus software.
I have the same problem before because of ESET NOD32 Antivirus 4,it will be solved when you uninstall the antivirus software rather than stop it.
(6,673 Views)
Perhaps you can check this KB.
I have the same issue with a Teledyne Camera.
Unable To Connect To Camera Error 0xBFF6902C - NI
Hope this helps.
Juan Navarro
(2,807 Views)
