Machine Vision
I cant calibrate my stereo cameras
Hello LabVIEW community,
As you can see in the photo, I'm using the LabVIEW stereo vision example to calibrate my stereo camera. Although I've followed all the instructions and the percentage is nearly 100%, the program is still acquiring photos and not giving me the .calib file as a "save as" option.
I've tried everything, and I hope to find a solution here. Thank you!
(915 Views)
Hello again,
I just figured it out and got the .calib file, but it seems there is a problem. The rectified image and depth map are both black screens.
I would be grateful if I could get a solution for that.
(877 Views)
Hello again, community,
I've managed to calibrate my stereo cameras, but there is a problem. The calibration quality wasn't good enough, as you can see in the photo. I would really appreciate any tips to improve the calibration quality.
(845 Views)
