Machine Vision
I cant use help files for vi's in LabView or IMAQ
I just installed a new LabVIEW 6.1 and IMAQ 6.1 and when I right click the vi's 'Help' is not on the pull down menu. I also do not have the current IMAQ vi reference manual. I found it on the cd but when I try to copy it I gat a message 'Not enough storage is available to complete this operation' I really depend on the vi specific pull down menu, can you help me?
(2,943 Views)
The help files may not have been installed when you did the original installation. To remedy this you can open the installer from the Add/Remove Programs applet and select the option to change or modify the installation. Then you can select to Add/Remove components which will give you a directory structure that allows you to select to install all of the support files. You may have to do this for "NI-IMAQ" (should be version 2.5.x) which is the hardware driver and "IMAQ Vision for LabVIEW" which is the add on analysis toolkit depending on which VI's are missing the help files.
JR A.
Application Engineer
(2,943 Views)
