Machine Vision
I do not see the vi IMAQdx once made the installer
Hi Everyone, I have the following problem. I have made ​​a program that displays the dainty pictures IMAQdx using two webcams and it works great but when I create an installer and install it on another computer and I get an error indicating that I was not with IMAQdx relaciondos encuentrarn VI. If someone happened to you or someone you know how to solve this problem would greatly appreciate if you help me.
Thank you,
(4,855 Views)
Hello Juan,
Check out this post that refers to a similar issue.
http://forums.ni.com/t5/Machine-Vision/Unable-to-create-an-installer-containing-IMAQdx-in-LabVIEW-20...
MCOTO
(4,804 Views)
