Machine Vision
I have had the same problem. Any new developments?
I have installed a vi that works fine on 2 of my XP machines. When I installed the vi on a PXI chasis running Windows 2000, I get the error loading NIvision.dll message. I have removed ALL the NI software, reloaded LabView 7.0, IMAQ 7.0, and I still get the same message. Any thoughts?
(3,312 Views)
Try to install Vision Run Time Engine and check out
(3,312 Views)
What version of the NIvision.dll is on each machine, (the ones that work and the one that throws the error message)? You can check the version in MAX by expanding the Software tree, selecting IMAQ Vision, and then the main part of the screen will display the version, such as 7.0.1.187.
Also, do other VIs exhibit the same problem? For example, what happens when you load a LabVIEW Vision shipping example on the Windows 2000 system?
Dawna P.
(3,312 Views)
