Machine Vision
I'm attempting to learn to use NI-IMAQ. Configuration Question
I'm attempting to learn to use NI-IMAQ. I'm currently using an HP laptop (Windows 7) and it has an in built laptop webcam (VGA) which I would like to use to learn how to use NI-IMAQ. I'm attempting to configure the device in the Measurement & Automation Explorer (as described in another help KB article) but the device is not showing up. Any suggestions would be appreciated.
(3,594 Views)
I have NI-IMAQ 4.1.6 installed. Is there additional software needed?
(3,593 Views)
Hey install this package NI IMAQ for USB.
Silver_Shaper | CLD
(3,587 Views)
In a related question... I'm having trouble determining if my webcamera (a Logitech C270) is Directshow compatible. Does anyone have an answer?
Also, is the mentioned NI-IMAQ for USB the same as IMAQ 4.6.4, NI-IMAQ I/O 2.2 and NI-IMAQdx 3.2?
(3,580 Views)
No all are different drivers.
Silver_Shaper | CLD
(3,576 Views)
You need to install IMAQdx, IMAQ won't be helpfull for you. And IMAQ-USB is not supported anymore.
And it seems that all logitech webcams are directshow compatibles.
Regards
(3,575 Views)
