Machine Vision
I'm green so please be kind.... The Imaq Find Circle Function returns an array of measurements (xy locations, area, etc). How can I save this data to an excel file?
Rico,
The output from the Find Circle function is an array of clusters, which you need to convert to a 2D array. The quickest way is autoindexing the array and converting each cluster to an array within the loop.
Once you have a 2D array, you can use "Write to Spreadsheet File" to write it to a tab delimited file, which can be read from Excel.
Bruce
Bruce Ammons
Ammons Engineering
(3,708 Views)
If you want to insert your data in an Excel worksheet:
- First convert your array of cluster into a 2D array as Bruce Ammonds has explained
- Then you should use the activeX commands of Excel to fill a worksheet of your data
But if you are 'green' this is not exactly a very easy approach.
Anyway, take a look at the example Write Table to Excel.vi in activeX examples of LV.
Good luck,
Alberto
(3,708 Views)
