Machine Vision
I m unable to execute a Imaqdx.vi present in Imaqdx.llb Which does nt allowing me 2 build application
Following error message has been generated while building application
Error 1502 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Save.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_EXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_EXE.lvclass:Build.vi -> AB_Engine_Build.vi -> AB_Build_Invoke.vi -> AB_Build_Invoke.vi.ProxyCaller
How can I Resolve this problem
(3,330 Views)
CAR 328824 has been filed to address this issue in a future release. In the meantime, make sure that the option "Remove unused members of project libraries" is enabled in the build specifications, under Additional Exclusions. That should fix the issue.
-Christophe
(3,291 Views)
Chris my project already has those settings so that does not fix the issue for me.  Any other ideas?
(3,237 Views)
