Machine Vision
I need a full A3 calibration grid for mashin vision
hello - can sombody help me?
elohaut
(4,130 Views)
You can create your own calibration grid in ms word.There are ready made grids availbale too. Make sure u measure the spacing properly(as accurately as possible).
(3,942 Views)
Hi Ofhadk,
     you may goto "...\Program Files\National Instruments\Vision\Documentation\CalibrationGrid.pdf" , then print it on your A3 paper. Eventually you need to "measure" the new distance between grid points. IMAQ takes care of calculating the corercted geometry based on your setting.
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(3,932 Views)
You can also create a grid in most drawing/paint programs.  Create a single dot, then duplicate it with a fixed spacing.
Bruce
Bruce Ammons
Ammons Engineering
(3,931 Views)
