Machine Vision
I need help with an error, code 1074396080.
 I am new to vision and labview, and I am using the vision assitant express. I want to to image/video processing, however when acquiring an avi file i get this error: IMAQ Vision: (Hex 0xBFF60450) Invalid Image Type. I have tried to extract HSI plane in the vision assistant express, but it does not help. If i connect a camera and acquire images I however can do image processing, but not in the case with a avi video file.
Will someone please help me?
(3,589 Views)
You are running into the 1074396080 error is because the image from the AVI file is converted to 8-bit picture after the HSI step in Vision ass. What you can do is to check the "Create Destination Image" setting in "Vision Ass. Express VI" under "Select Controls".
Hope this helps.
Thanks!
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
(3,551 Views)
