Machine Vision
I need use the line data(basler spl2048 camera,NI1433 board) to perform FFT transform ,how can i use transformed data to construct an image
hello everyone! as what i haved mentioned in the title.In optical coherence tomography system ,i need to perform for every line data whick accquired by NI1433,how can i use the transformed data tto construct an depth image .
(5,150 Views)
Do you mean basic signal/image reconstruction for OCT or technical question about NI1433 board?
Also what type of OCT scan are you doing?
Image reconstruction in full-field Fourier-domain optical coherence tomography
http://iopscience.iop.org/1464-4258/7/7/013
Curt Corum, Ph.D.
Center for Magnetic Resonance Research
University of Minnesota
(5,139 Views)
My OCT system is spectral domain OCT system.OCT scan is only horizontal scaning using synchronize line camera with galvatometers.I don't know how to use the FFT line data to construct the image in labview .Could you give me some advices?
(5,134 Views)
This is no longer my main area of expertise, but here is results of brief search:
Spectral Domain Optical Coherence Tomography System Design: sensitivity fall-off and processing speed enhancement
look at Chapter 5
https://circle.ubc.ca/bitstream/id/91474/ubc_2010_fall_chan_kenny.pdf
Ultrahigh-resolution, high-speed, Fourier
domain optical coherence tomography and
methods for dispersion compensation
http://www.opticsinfobase.org/oe/abstract.cfm?uri=OE-12-11-2404
hope this helps,
Curt
Curt Corum, Ph.D.
(5,060 Views)
