Machine Vision
I tried a simple snap vi and all I got was a weird error message
Go to device manager and verify that your 1394 *card* is using the Microsoft driver. Then verify that the camera shows up in device manager and is associated with the IMAQdx driver.
Eric
Message 11 of 19
(2,539 Views)
Thank you for your prompt response, actually that is what lead me to install Pylon's software. Its because the camera didn't show up in the Device Manager nor MAX.
Is it possible that what I'm facing in difficulties with the camera is because of the evaluation versions that I'm using ?
Message 12 of 19
(2,524 Views)
Accepted by topic author Mishal_
It shouldn't, because MAX will always work regardless of license status.
If the camera doesn't show up in device manager, do you at least see your 1394 card? What driver is it listed as using?
Eric
Message 13 of 19
(2,520 Views)
VIA OHCI Complaint IEEE 1394 Host Controller No I meant the vision software that is an evaluation version
Message 14 of 19
(2,518 Views)
I'd check the cables and camera. I don't believe the 601 has any LEDs indicating it is powered on. The camera being detected by the OS happens prior to any NI software being involved, so there's not much troubleshooting you can do inside the NI software. Try swapping cameras or trying the same camera in a different PC. Either the firewire port on your PC or the camera itself could be broken. We've seen this happen a lot when the 1394a connectors are inserted backwards and both ports can become fried.
Eric
Message 15 of 19
(2,507 Views)
You're absolutely right there's no LED indicator. I well investigate the equipment. Thank you Eric Thank you everybody I know I've been a pain but I'm really invested in this project.
Message 16 of 19
(2,505 Views)
Did you ever end up figuring out the error?  I am having the same problem.
I am using a Basler acA640-90gc camera, NI MAX 5.4, and a NI PXI/PCIe-8231 interface device.
Message 17 of 19
(2,110 Views)
I am running into a similar issue with a Basler aCA2500-14gc and NI PCIe 8233. I am unable to view the camera (and the card) in MAX, and am unable to view a serial or IP in pylon. I have tried using an ethernet switch between the card and the camera to set them to the same subnet, and have tried disabling firewalls. The status lights on the card are active, but no status lights are available on the camera itself. The camera does get warm, so I know it is recieving power over ethernet. I have tried swapping cables as well.
The card does show up in Windows Device Manager, listed under Network Adapters as "NI PCIe-8233 Ethernet Adapter", but it does not show up under NI devices. According to NI tech. support this is typical behavoir for this card. Any reson why they would sell a card that is known to not be recognized by MAX? Also, more importantly, any suggestions as to how to get MAX to take an image?
Message 18 of 19
(2,039 Views)
Network cards are not displayed in MAX, only the cameras that are connected to them show up. This is the same behavior as FireWire cards/cameras have. It is simply a result that it is more of a bus interface rather than a fixed framegrabber. Some network cards like the PCIe-8237R have additional programmable functionality and so they do show up in MAX, but the cameras still show up under a different category, not under the card.
Message 19 of 19
(2,033 Views)
