Machine Vision
IC-3120 vs CVS-1458
Is the IC-3120 the same as a CVS-1458 without VBAI? They appear to have the same specs and form factor.
(3,854 Views)
Accepted by topic author Photon_Dan
Correct. It's a rename so it's more clear that it can be used for more than just Vision applications (USB cDAQ can connect to either for even more application areas that  can be addressed.)
(3,827 Views)
indeed it is some thing like industrial pc for doing industrial machine vision projects in such project
you need to read some sensor or make some pulse for comment some equipment or send some data via ethernet
(3,815 Views)
I'd like to add that the specification documents list different amounts of non-volatile memory for the two systems:
IC-3120: 2 GB (https://www.ni.com/docs/en-US/bundle/ic-3120-specs/page/specs.html)
CVS-1458: 32 GB (https://www.ni.com/docs/en-US/bundle/cvs-1458-specs/resource/375271a.pdf)
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
(3,230 Views)
