Machine Vision
IMAG AVI Get Filter Names comes back empty
Taking the list of codec from "DxDiag" doesn't work for every codec: for some of them LabVIEW say "Error -1074396006 occurred at IMAQ AVI Create Unknown compression filter."
Any suggestion?
Message 11 of 21
(2,442 Views)
Pier Paolo -
The NI Vision Development Module doesn't work with all compression filters.  We first do a preliminary test to see if we can be compatible with the filter, and if this test fails then we don't return it in IMAQ AVI Get Filter Names, and we won't accept it in IMAQ AVI Create.  Is there a particular compression filter you're interested in using?
Greg Stoll
Greg Stoll
LabVIEW R&D
Message 12 of 21
(2,430 Views)
Dear Greg
I want to save a video 8bits gray levels image without loosing quality. I'd like to compress it to have smaller files.
Could you suggest me anyone compatible with LabVIEW2009?
Pier Paolo
Message 13 of 21
(2,428 Views)
Running "Read AVI example" I have this error:
"Error -1074395975 occurred at IMAQ AVI Read Frame
 DirectX has timed out reading or writing the AVI file.  When closing an AVI file, try adding an additional delay.  When reading an AVI file, try reducing CPU and disk load."
Does anybody know why and how to solve it?
Pier Paolo Monticone
Message 14 of 21
(2,348 Views)
Pier Paolo -
I'd recommend trying the AVI Compressor Comparison Example - this will run an .avi file through all the filters available on your system and report how long each takes, how big the resulting .avi file is, and a measure of how good the quality is.
Greg Stoll
Greg Stoll
LabVIEW R&D
Message 15 of 21
(2,347 Views)
Thanks, however I've again the error:
Message 16 of 21
(2,345 Views)
Which .avi file are you trying to read when you get this error?  Can you read any of the ones in the examples folder?
Greg Stoll
Greg Stoll
LabVIEW R&D
Message 17 of 21
(2,344 Views)
I used one non compressed AVI file of 2GB because the default one give this error:
Error -1074395993 occurred at IMAQ AVI Open
  File I/O error.
Message 18 of 21
(2,342 Views)
Hmm, the File I/O error makes it sound like something's wrong with the file.  Can you play it in Windows Media Player?
Also, do you have a smaller .avi to try reading?  It's possible the large size is causing problems...
Just throwing out some ideas,
Greg Stoll
Greg Stoll
LabVIEW R&D
Message 19 of 21
(2,338 Views)
Message 20 of 21
(2,312 Views)
