Machine Vision
IMAQ 6.0 is missing IMAQ CreateErrorCluster
On top of LabVIEW Pro 6.0.3 I installed IMAQ 6.0. Everything installed correctly but when I did a mass compile, a few IMAQ VIs failed because of a missing utility VI called "IMAQ CreateErrorCluster". I can't find this VI anywhere on my system. It must have been left out of the IMAQ distro CD-ROM. Does anyone know where I can get it?
(3,303 Views)
What version of IMAQ did you previously have. Also, check what version of NI-IMAQ you have. The most recent version is 2.5.1.
(3,303 Views)
I had no version of IMAQ. The only thing previously installed was LabVIEW Pro 6.0.3. It had a small handful of IMAQ widgets.
It should not matter what version I previously had though, even if there were one. The installer should be smart enough to know what to do.
It generally was, but this single missing VI causes a few others to break. Based on the mass-compile results it seems to be the only missing VI.
Mark
(3,303 Views)
