Machine Vision
IMAQ Browser Trouble
I'm trying to set up an IMAQ browser to view selections of an image,
but I'm having trouble getting it going. Does anyone have an example of
a browser that I could use to figure out how they work?
Josh Vaughan
jvaughan@reed.edu
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(6,190 Views)
Josh,
There is a fairly simple example that ships with the driver software,
NI-IMAQ. It is in the HL Sequence example which you can get through
....\labview\example\imaq\imaq high level.llb\HL sequence with IMAQ
Vision display.vi
If you do not have this installed you either have not installed the
driver or did not select the option to install the IMAQ LabVIEW
examples. You can add these back in by running the driver installer.
The latest version of the driver is NI-IMAQ 2.2 and can be found on
National Instruments website.
Tony Iglesias
In article <7moe53$toi$1@nnrp1.deja.com>,
of
> a br
> Josh Vaughan
> jvaughan@reed.edu
(6,190 Views)
Josh,
I thought I had posted a reply yesterday but I can't find it here
today...
Anyway, a good place to find a simple ixample of how to use the browser
is actually ships with the driver software NI-IMAQ. You can find this
in the ...\LabVIEW\examples\IMAQ\IMAQ High Level.llb\HL Sequence in IMAQ
Vision Display.vi
If you do not have this directory, it means one of two things:
1)you do not have the driver installed
2)when installing the driver, you opted not to include the IMAQ examples
Either way the fix would be easy. You can download the driver software
from National Instruments website. The current version is 2.2.
Tony Iglesias
ions of an image,
of
> Josh Vaughan
> jvaughan@reed.edu
(6,189 Views)
