Machine Vision
IMAQ Card doesn't recognise on-board 8Mb of Memory
Replaced faulty IMAQ card with another one and it would not recognise its onboard 8MB of memory?
(3,118 Views)
Which IMAQ card are you using? There are two types of memory architectures used for National Instruments IMAQ boards; either a 4KB FIFO (First In First Out) buffer, or a minimum of 16 MB of onboard memory. To my knowledge, none of our current boards have 8MB of onboard memory. Please refer to the following knowledge base on our website that describes the onboard memory of our image acquisition cards in more detail, Knowledge Base 2IAABM8M: What Are the Onboard Memory Requirements for Images on the NI-IMAQ Boards?
Also, can you please provide more detail about how you determined that the card does not recognize its onboard memory? It may be that your image acquisi
tion is exceeding the onboard memory of the board. For example, with an 8-bit 640x480 image, you could fit about 50 buffers in a 16 MB onboard memory.
I would also recommend that you run the diagnostic utility for the card and make sure that it passes all the tests. If the card fails the diagnostics, then you will need to contact National Instruments to have the card repaired.
Best wishes,
D. Putnam
(3,118 Views)
The IMAQ Card is a 1424 (16MB).
Diagnostics finds no fault.
The problem was found in MAX, on a known good card it reports 8MB of onboard memory on this one it reports 0MB. The card will not function with our own software, I presume due to this.
Andy
(3,118 Views)
