Machine Vision
IMAQ Copy - Data does not stick around
First off, Thank you in advance for any help you can offer.
I am rather new to LabVIEW – so I may have made an obvious mistake.
I am continuously capturing video images in my buffer (works fine).
I would like to use the 100th frame from the camera & subtract it from all future frames. I am using the “IMAQ Copy” to save the 100th frame to an item called Copy_of_Image.
For some reason Copy_of_Image does not keep the image data.  And I don’t know why.  I don't think I'm using IMAQ Copy correctly.  (I know it produces a reference to the destination image, but how do I access the image data?)
My code is attached.
- lisa
(Lab VIEW 8.2 most recent versions of IMAQ/Vision)
Message Edited by -lisa on 10-10-2007 12:38 PM
(3,533 Views)
Hi lisa.
Once you have used IMAQ Copy you do not store it for usage in further iterations of your while loop.
Attached is a modification of your VI that uses a shift register to access the copy.
Hope this helps, Guenter
(3,516 Views)
That's it!!  Thank you very very much Guenter!  Smiley Happy
- lisa
(3,507 Views)
